跳转到主内容
加入维修社区 - 创建账户
Super Nintendo Eject Button Replacement
你所需要的
  1. Super Nintendo Eject Button Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
  2. Super Nintendo Eject Button Replacement: 步骤 2 中的图像 1,3 Super Nintendo Eject Button Replacement: 步骤 2 中的图像 2,3 Super Nintendo Eject Button Replacement: 步骤 2 中的图像 3,3
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
  3. Super Nintendo Eject Button Replacement, Eject Button: 步骤 3 中的图像 1,2 Super Nintendo Eject Button Replacement, Eject Button: 步骤 3 中的图像 2,2
    • Lift the right side of the eject lever out of the housing.
  4. Super Nintendo Eject Button Replacement: 步骤 4 中的图像 1,3 Super Nintendo Eject Button Replacement: 步骤 4 中的图像 2,3 Super Nintendo Eject Button Replacement: 步骤 4 中的图像 3,3
    • Pull the metal bar out through the right side of the eject lever.
    • Make sure to keep track of the spring located on the left side of the lever as it may shoot off when removing the metal bar.
    • When reassembling, the procedure becomes more difficult due to the spring (marked red). We recommend that one person hold the spring in place (picture 3) while another person slides the metal bar back into the left housing, and slide the eject lever onto the metal bar.
结论
To reassemble your device, follow the instructions in reverse order.
12等其他人完成本指南。
James Shirley
于10/03/10注册
1,027 声望
创作了2篇指南
团队
Cal Poly, Team 4-47, Amido Fall 2010 Cal Poly, Team 4-47, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G47
4 名成员
创作了25篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 37
过去 30 天: 139
总计 20,510
