跳转到主内容
加入维修社区 - 创建账户
Super Nintendo Controller Port Replacement
你所需要的
  1. Super Nintendo Controller Port Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
  2. Super Nintendo Controller Port Replacement: 步骤 2 中的图像 1,3 Super Nintendo Controller Port Replacement: 步骤 2 中的图像 2,3 Super Nintendo Controller Port Replacement: 步骤 2 中的图像 3,3
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
  3. Super Nintendo Controller Port Replacement, Eject Button: 步骤 3 中的图像 1,2 Super Nintendo Controller Port Replacement, Eject Button: 步骤 3 中的图像 2,2
    • Lift the right side of the eject lever out of the housing.
  4. Super Nintendo Controller Port Replacement: 步骤 4 中的图像 1,3 Super Nintendo Controller Port Replacement: 步骤 4 中的图像 2,3 Super Nintendo Controller Port Replacement: 步骤 4 中的图像 3,3
    • Pull the metal bar out through the right side of the eject lever.
    • Make sure to keep track of the spring located on the left side of the lever as it may shoot off when removing the metal bar.
    • When reassembling, the procedure becomes more difficult due to the spring (marked red). We recommend that one person hold the spring in place (picture 3) while another person slides the metal bar back into the left housing, and slide the eject lever onto the metal bar.
  5. Super Nintendo Controller Port Replacement, Controller Port: 步骤 5 中的图像 1,1
    • Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
  6. Super Nintendo Controller Port Replacement: 步骤 6 中的图像 1,2 Super Nintendo Controller Port Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the ribbon cable from its port.
结论
18等其他人完成本指南。
James Shirley
于10/03/10注册
1,033 声望
创作了2篇指南
团队
Cal Poly, Team 4-47, Amido Fall 2010 Cal Poly, Team 4-47, Amido Fall 2010 的会员
CPSU-AMIDO-F10S4G47
4 名成员
创作了25篇指南
3指南评论
I did a complete teardown of my 26 year old super Nintendo because I had to fix the AV jack. the hardest part was the de soldering. however upon putting it back together I could get the games to play, however it was in black and white…or even a grayish hue…and the controllers didn't work. shortly after the ribbon connecting the controller input to the system snapped on one end. do you think this was the issue, and where do I find a new one? Thanks.
Keith Goetting - 回复 分享
This isn’t complete. How about taking the face plate off?
Daniel Powers - 回复 分享
Find don’t look like screws they look like rivets
Steve Pitcher - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 42
过去 30 天: 215
总计 36,817
