跳转到主内容
Super Nintendo Cartridge Battery Replacement
你所需要的
  1. Super Nintendo Cartridge Battery Replacement, Battery: 步骤 1 中的图像 1,3 Super Nintendo Cartridge Battery Replacement, Battery: 步骤 1 中的图像 2,3 Super Nintendo Cartridge Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the two 3.8mm security screws from the front panel of the game cartridge using a 3.8mm Gamebit screwdriver to reveal the circuit board.
    • It's good to have a white mat or bright sheet on your work surface to be able to see any small items like screws more easily and protect the surface from damage like hot solder dripping down.
  2. Super Nintendo Cartridge Battery Replacement: 步骤 2 中的图像 1,3 Super Nintendo Cartridge Battery Replacement: 步骤 2 中的图像 2,3 Super Nintendo Cartridge Battery Replacement: 步骤 2 中的图像 3,3
    • Mount the circuit board on to the adjustable circuit board holder.
    • Desolder the two soldering points on the back of the circuit board holding the battery in place to remove the battery.
    • Use a soldering rest or holder to avoid damage to the surface when you need to put the soldering iron down.
  3. Super Nintendo Cartridge Battery Replacement: 步骤 3 中的图像 1,2 Super Nintendo Cartridge Battery Replacement: 步骤 3 中的图像 2,2
    • Use the soldering iron and the de-soldering braid to remove any excess soldering adhesive.
    • Excess solder needs to be removed so that the new battery can be mounted properly.
  4. Super Nintendo Cartridge Battery Replacement: 步骤 4 中的图像 1,2 Super Nintendo Cartridge Battery Replacement: 步骤 4 中的图像 2,2
    • Use the soldering iron with the soldering wire on the two soldering points to adhere the new battery to the circuit board.
  5. Super Nintendo Cartridge Battery Replacement: 步骤 5 中的图像 1,2 Super Nintendo Cartridge Battery Replacement: 步骤 5 中的图像 2,2
    • Place the circuit board back into the cartridge and screw the front panel back in place with the 3.8mm security screws using a 3.8mm Gamebit screwdriver.
    • Optional: It would be advisable to clean the finished circuit board before mounting it back into the cartridge.
终点
另外一个人完成了本指南。
Mohamad Mohamad
于01/18/21注册
436 声望
创作了3篇指南
团队
York University, Team M-6, Allen Summer 2023 York University, Team M-6, Allen Summer 2023 的会员
YORK-ALLEN-SU23SMG6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 29
过去 30 天: 132
总计 1,147
