此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
要重新组装设备,请按相反顺序执行这些说明。
17等其他人完成本指南。
2指南评论
Any tips on how to tell if it's the power switch that needs replacing vs something else?
TopShopGames - 回复 分享
Look at it for any signs of physical damage, if you don't see any noticeable issues that you can fix then you can try cutting the two wires stripping off the ends of them, and very carefully touching the wires together while its plugged in. BE EXTREMELY CAREFUL WHILE DOING THIS DO NOT TOUCH THE EXPOSED WIRE. If you notice it turn on, immediately stop touching the wires together and unplug the console. This means that the switch itself is broken. If it doesn't turn on, stop touching the wire together and unplug the console. This means that it's likely a power cable issue.
Anders Hoff - 回复 分享
