跳转到主内容
Sungale CyberUs Battery Replacement
你所需要的
  1. Sungale CyberUs Battery Replacement, Screen: 步骤 1 中的图像 1,1
    • Make sure to have the device turned off to prevent any minor electric shock.
    • Hold the device so the left side is facing towards you (like in the picture shown) so the two 4mm PH001 screws are exposed and easier to access.
  2. Sungale CyberUs Battery Replacement: 步骤 2 中的图像 1,1
    • Remove both 4mm PH001 screws from the side panel.
  3. Sungale CyberUs Battery Replacement: 步骤 3 中的图像 1,2 Sungale CyberUs Battery Replacement: 步骤 3 中的图像 2,2
    • Carefully pry up one of the top corners of the screen with a plastic spudger (prying tool). Slide the tool along the edges to release it from the housing.
    • The screen may make some cracking noises as you pry it from the casing. This is expected.
    • The screen is still connected to the motherboard. Use force with caution.
  4. Sungale CyberUs Battery Replacement: 步骤 4 中的图像 1,1
    • Gently turn screen over, to the side, to reveal the ZIF connector attached to the motherboard.
  5. Sungale CyberUs Battery Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Gently using tweezers, flip the black clip up. Pull the ZIF connector out.
    • You screen is still not completely detached from the device.
  6. Sungale CyberUs Battery Replacement: 步骤 6 中的图像 1,2 Sungale CyberUs Battery Replacement: 步骤 6 中的图像 2,2
    • Using the prying tool, slide the black clip out. Pull the ZIF connector out and to the left, the screen is now detached from the motherboard.
  7. Sungale CyberUs Battery Replacement, Battery: 步骤 7 中的图像 1,1
    • Now, carefully we will remove the battery. Find the leads, or the red and black wires going to the battery from the motherboard. To free the wires you must cut the wire near the battery leads. Make sure both ends are clean and have enough exposed wire.
  8. Sungale CyberUs Battery Replacement: 步骤 8 中的图像 1,1
    • You will have to clean the connections and solder the new battery back into place. Just as before, you want to reconnect the new battery to the motherboard.
结论
Grayson Heinbaugh
于10/03/16注册
158 声望
撰写一个指南
团队
IUPUI, Team 1-4, Harley Fall 2016 IUPUI, Team 1-4, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S1G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 163
