跳转到主内容
Sunbeam Snow Cone Maker Motor Replacement
你所需要的
  1. Sunbeam Snow Cone Maker Motor Replacement, Dasher: 步骤 1 中的图像 1,1
    • Push the button on the back to release the lid. (Missing on this example device.)
    • In the photo on the device page it is red.
  2. Sunbeam Snow Cone Maker Motor Replacement: 步骤 2 中的图像 1,2 Sunbeam Snow Cone Maker Motor Replacement: 步骤 2 中的图像 2,2
    • Unscrew the dasher by holding it in the middle and turning clockwise.
    • You will have to spin it quite a bit.
    • Remove the dasher.
    • Alternately, you can continue to step 3 to further disassemble the dasher components.
  3. Sunbeam Snow Cone Maker Motor Replacement: 步骤 3 中的图像 1,2 Sunbeam Snow Cone Maker Motor Replacement: 步骤 3 中的图像 2,2
    • To take the dasher apart, remove the three 5.5 mm Phillips #00 screws embedded in the plastic. **The 3rd screw is behind the hand in the picture
    • Carefully pull the two pieces apart.
    • When you've finished taking apart the dasher, you should have two parts that are shown in the second picture in this step.
  4. Sunbeam Snow Cone Maker Motor Replacement, Motor: 步骤 4 中的图像 1,1
    • After removing the dasher, turn the device so that you can see the “lock” and “unlock” symbols on the back.
    • Twist the casing so that it is in the unlocked position and remove it from the bottom half of the machine.
  5. Sunbeam Snow Cone Maker Motor Replacement: 步骤 5 中的图像 1,2 Sunbeam Snow Cone Maker Motor Replacement: 步骤 5 中的图像 2,2
    • Unscrew the five screws and remove the piece labeled in the picture. You should now be able to see the motor.
  6. Sunbeam Snow Cone Maker Motor Replacement: 步骤 6 中的图像 1,1
    • Lay the device on its side.
    • Remove the 4 gray rubber “feet” by pulling them straight off.
    • Remove the four 5.5 mm Phillips #00 screws that are under them.
    • Remove the bottom plastic cover.
  7. Sunbeam Snow Cone Maker Motor Replacement: 步骤 7 中的图像 1,1
    • Remove the two 5.5 mm Phillips #00 screws holding a bracket to keep the cord in place.
    • Remove the the bracket so the chord has room to move.
  8. Sunbeam Snow Cone Maker Motor Replacement: 步骤 8 中的图像 1,3 Sunbeam Snow Cone Maker Motor Replacement: 步骤 8 中的图像 2,3 Sunbeam Snow Cone Maker Motor Replacement: 步骤 8 中的图像 3,3
    • Remove the topmost two 5.5 mm Phillips #00 screws that hold the motor in the case.
    • Remove and replace the motor.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,069
