跳转到主内容
Sunbeam Snow Cone Maker Dasher Replacement
你所需要的
  1. Sunbeam Snow Cone Maker Dasher Replacement, Dasher: 步骤 1 中的图像 1,1
    • Push the button on the back to release the lid. (Missing on this example device.)
    • In the photo on the device page it is red.
  2. Sunbeam Snow Cone Maker Dasher Replacement: 步骤 2 中的图像 1,2 Sunbeam Snow Cone Maker Dasher Replacement: 步骤 2 中的图像 2,2
    • Unscrew the dasher by holding it in the middle and turning clockwise.
    • You will have to spin it quite a bit.
    • Remove the dasher.
    • Alternately, you can continue to step 3 to further disassemble the dasher components.
  3. Sunbeam Snow Cone Maker Dasher Replacement: 步骤 3 中的图像 1,2 Sunbeam Snow Cone Maker Dasher Replacement: 步骤 3 中的图像 2,2
    • To take the dasher apart, remove the three 5.5 mm Phillips #00 screws embedded in the plastic. **The 3rd screw is behind the hand in the picture
    • Carefully pull the two pieces apart.
    • When you've finished taking apart the dasher, you should have two parts that are shown in the second picture in this step.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 797
