跳转到主内容
Sunbeam Mini Pie Maker FPSBPMM980 Disassembly
你所需要的
  1. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 1 中的图像 1,3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 1 中的图像 2,3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly, Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 1 中的图像 3,3
    • Open the pie maker.
    • Remove four 4 mm screws holding the crescent-shaped black plastic plate in place with a Phillips #1 screwdriver.
    • Remove the black crescent-shaped plastic plate.
  2. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 2 中的图像 1,2 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 2 中的图像 2,2
    • Repeat the previous step to remove the upper black crescent-shaped plastic plate from the upper half of the unit.
    • The pie maker's symmetrical construction may cause confusion—in this image the pie maker is resting on its upper half.
  3. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 3 中的图像 1,1
    • Remove the four 4 mm screws located directly on either side of the hinges with a Phillips #1 screwdriver.
    • Successfully removed screws will allow for the separation of the pan component from the outer plastic shell.
  4. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 4 中的图像 1,3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 4 中的图像 2,3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 4 中的图像 3,3
    • Remove the final two 4 mm screws from the circular black plastic bottom base plate with a Phillips #1 screwdriver.
    • Remove the black plastic base.
  5. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 5 中的图像 1,3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 5 中的图像 2,3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 5 中的图像 3,3
    • Disconnect the two red and green incandescent lights from their fixtures by popping them out of their red plastic cradles.
  6. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 6 中的图像 1,3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 6 中的图像 2,3 Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 6 中的图像 3,3
    • Examine successfully disassembled Sunbeam Mini Pie Maker FPSBPMM980.
    • If desired, remove insulatory coated paper cut outs to more easily access heating coils.
  7. Sunbeam Mini Pie Maker FPSBPMM980 Disassembly: 步骤 7 中的图像 1,1
    • Examine electronics schematic.
    • The Sunbeam Pie Maker utilizes four heating coils to bring miniature pies to an internal temperature of 175+ F. The pies are placed in the appliance after pre-heating, and are cooked for approximately 10 minutes, or until golden brown. The machine begins pre-heating upon being plugged in, signifying it is receiving power with the red light.
结论
To reassemble your device, follow these instructions in reverse order. Happy fixing!
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 129
