跳转到主内容
Sun King Solo Solar Lantern Hand Strap Replacement
你所需要的
  1. Sun King Solo Solar Lantern Hand Strap Replacement, Locate and Remove the Screws: 步骤 1 中的图像 1,1
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Hand Strap Replacement, Separate the Device: 步骤 2 中的图像 1,1
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Hand Strap Replacement, Remove Strap: 步骤 3 中的图像 1,1
    • Remove both ends of the strap from the orange casing by pulling up.
  4. Sun King Solo Solar Lantern Hand Strap Replacement, Replace the Strap: 步骤 4 中的图像 1,1
    • Insert the ends of the new strap into the strap housing on both sides of the orange component.
    • Either strap housing (inner or outer) can be used to adjust the strap length.
结论
Anna
于10/23/14注册
595 声望
创作了4篇指南
团队
Michigan Tech, Team 1-3, Lauer Fall 2014 Michigan Tech, Team 1-3, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 317
