跳转到主内容
Sun King Solo Solar Lantern Casing Cleaning
你所需要的
  1. Sun King Solo Solar Lantern Casing Cleaning, Locate and Remove the Screws: 步骤 1 中的图像 1,1
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Casing Cleaning, Separate the Device: 步骤 2 中的图像 1,1
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Casing Cleaning, Cleaning the Casing: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    购买
    • Using a microfiber cleaning cloth, wipe the debris or condensation from the clear plastic of the device.
    • Buildup of condensation in the device could be due to broken or damaged seals. Click here for a seal replacement guide.
结论
Anna
于10/23/14注册
607 声望
创作了4篇指南
团队
Michigan Tech, Team 1-3, Lauer Fall 2014 Michigan Tech, Team 1-3, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 364
