跳转到主内容
Sun King Solo Solar Lantern Battery Replacement
你所需要的
  1. Sun King Solo Solar Lantern Battery Replacement, Locate and Remove the Screws: 步骤 1 中的图像 1,1
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Battery Replacement, Separate the Device: 步骤 2 中的图像 1,1
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Battery Replacement, Isolate the Battery: 步骤 3 中的图像 1,2 Sun King Solo Solar Lantern Battery Replacement, Isolate the Battery: 步骤 3 中的图像 2,2
    • Locate the battery.
    • Gently lift the battery from the device.
  4. Sun King Solo Solar Lantern Battery Replacement, Remove the Battery: 步骤 4 中的图像 1,1
    • Locate the clip attaching the battery pack to the circuit board.
    • Use tweezers to remove the portion of the clip attached to the battery.
    • Do not pull directly on the wires! They can easily be damaged.
  5. Sun King Solo Solar Lantern Battery Replacement, Replace the Battery: 步骤 5 中的图像 1,1
    • Align the black wire of the new battery towards the center of the device.
    • Press down firmly on the clip to insure that it is properly connected.
    • Properly dispose of the Lithium-Ion Battery. Lithium Battery Disposal
  6. Sun King Solo Solar Lantern Battery Replacement, Reseat the Battery: 步骤 6 中的图像 1,1
    • Seat the battery in the orange component so that the short end of the battery pack is touching the foam bumper.
结论
6等其他人完成本指南。
Anna
于10/23/14注册
595 声望
创作了4篇指南
团队
Michigan Tech, Team 1-3, Lauer Fall 2014 Michigan Tech, Team 1-3, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G3
3 名成员
创作了5篇指南
8条评论
please help in finding the life p04 battery,3.2v ,1500 mah,batch #20309
SHARATH PONUGOTI - 回复
as my solar lights battery is dead..iam unable to find out whr i will get a new one
where to get the battery spare part?
johnkoisasi - 回复
Please help me in finding PRO sunking battery 6.6v,1450mAh, Batch 30130.
Please contact me:stanleymayor944@yahoo.com
Stanley - 回复
Howi can get 6.6 v sunking pro battery?please help me.
kapildeo mandal - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 3,993
