跳转到主内容
Summer 3D Lite Convenience Stroller Back Wheel Replacement
  1. Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: 步骤 1 中的图像 1,2 Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: 步骤 1 中的图像 2,2
    • Set the stroller up so the front wheel is on the ground with the metal push tab up.
  2. Summer 3D Lite Convenience Stroller Back Wheel Replacement: 步骤 2 中的图像 1,2 Summer 3D Lite Convenience Stroller Back Wheel Replacement: 步骤 2 中的图像 2,2
    • Push the tab in with your finger enough so the plastic can slip out above the tab.
  3. Summer 3D Lite Convenience Stroller Back Wheel Replacement: 步骤 3 中的图像 1,1
    • OPTIONAL: If the tab is being difficult, use a key to push the tab in further in order to slip plastic out of place.
  4. Summer 3D Lite Convenience Stroller Back Wheel Replacement: 步骤 4 中的图像 1,1
    • The wheel should slide right off the pole once the tab is pushed out of place. It is now possible to make repairs or replace the wheel completely.
结论
4等其他人完成本指南。
Nick Taylor
于09/28/15注册
188 声望
撰写一个指南
团队
Cal Poly, Team 11-5, Forte Fall 2015 Cal Poly, Team 11-5, Forte Fall 2015 的会员
CPSU-FORTE-F15S11G5
4 名成员
创作了3篇指南
2条评论
Gd, have a question . Were can u buy spare parts for this type of stroller?
pieterroos - 回复
Can you tell me if you have a rear wheel that will fit a summer 3D go convenience stroller all black?
charles nelms - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 109
总计 11,077
