跳转到主内容
Subaru Legacy 2009 Key Fob Battery Replacement
你所需要的
  1. Subaru Legacy 2009 Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 1,2 Subaru Legacy 2009 Key Fob Battery Replacement, Key Fob Battery: 步骤 1 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove a 5.0 mm screw from the base of the key fob.
  2. Subaru Legacy 2009 Key Fob Battery Replacement: 步骤 2 中的图像 1,2 Subaru Legacy 2009 Key Fob Battery Replacement: 步骤 2 中的图像 2,2
    • Place the flat end of a spudger into the gap between the key blank (metal part) and the case.
    • Gently pry upward to separate the housing.
  3. Subaru Legacy 2009 Key Fob Battery Replacement: 步骤 3 中的图像 1,1
    • Once the case comes apart, turn the key upside down, and the keyless fob should easily come out.
  4. Subaru Legacy 2009 Key Fob Battery Replacement: 步骤 4 中的图像 1,3 Subaru Legacy 2009 Key Fob Battery Replacement: 步骤 4 中的图像 2,3 Subaru Legacy 2009 Key Fob Battery Replacement: 步骤 4 中的图像 3,3
    • Use a spudger or your fingernails to pry open the four clips securing the keyless fob.
    • Ensure that you pinch the fob on the side, not the top, during the opening to avoid accidentally re-securing the clips.
  5. Subaru Legacy 2009 Key Fob Battery Replacement: 步骤 5 中的图像 1,3 Subaru Legacy 2009 Key Fob Battery Replacement: 步骤 5 中的图像 2,3 Subaru Legacy 2009 Key Fob Battery Replacement: 步骤 5 中的图像 3,3
    • Gently slide a spudger beneath the battery to lift it from the case.
    • Replace it with a new CR1620 3V lithium coin battery.
    • Reassemble the key fob.
结论
Brandon Lu
于01/09/24注册
121 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 138
