跳转到主内容
Straight Leg Canopy Tent Arm Replacement
你所需要的
  1. Straight Leg Canopy Tent Arm  Replacement, The Tent Arm: 步骤 1 中的图像 1,2 Straight Leg Canopy Tent Arm  Replacement, The Tent Arm: 步骤 1 中的图像 2,2
    • Steps 1 through 3 are for removal of the broken arm.
    • At the top joint, there will be a nut in the back that is holding the screw in place.
    • Use the wrench to hold the nut in place.
    • Use the Phillips screwdriver to unscrew the screw.
  2. Straight Leg Canopy Tent Arm  Replacement: 步骤 2 中的图像 1,3 Straight Leg Canopy Tent Arm  Replacement: 步骤 2 中的图像 2,3 Straight Leg Canopy Tent Arm  Replacement: 步骤 2 中的图像 3,3
    • Repeat step 1 for the other two joints.
    • There is no need to hold the nut with the wrench for the middle joint because this joint holds two arms together.
    • The nut is in the middle of the two arms, so once you have loosened the screw, the black connector will come off.
    • Hold the nut in place and finish unscrewing the screw.
  3. Straight Leg Canopy Tent Arm  Replacement: 步骤 3 中的图像 1,1
    • Remove the arm(s), after all three joints are unscrewed.
  4. Straight Leg Canopy Tent Arm  Replacement: 步骤 4 中的图像 1,1
    • Steps 4 through 7 are for arm replacement.
    • Replace the new arm, starting at the top joint again.
    • Place the screw through the hole and twist the nut on the backside of the screw.
    • Hold the nut with the wrench while you screw the screw to make it tight.
  5. Straight Leg Canopy Tent Arm  Replacement: 步骤 5 中的图像 1,2 Straight Leg Canopy Tent Arm  Replacement: 步骤 5 中的图像 2,2
    • At the middle joint, place the screw through the hole in the black plastic connector and through the conjoining arms.
    • Use the Phillips screwdriver to tighten the screw in place.
  6. Straight Leg Canopy Tent Arm  Replacement: 步骤 6 中的图像 1,1
    • Repeat step 4 for the bottom joint.
    • Remember to use the wrench to hold the nut in place while you screw the screw back tightly.
  7. Straight Leg Canopy Tent Arm  Replacement: 步骤 7 中的图像 1,2 Straight Leg Canopy Tent Arm  Replacement: 步骤 7 中的图像 2,2
    • Replace the canopy top by attaching the Velcro pieces.
    • Once all of the joints have been tightly screwed back in place, the tent should be ready to reuse again.
结论
After following these instructions in chronological order, the end result would be for the successful removal and replacement of an arm on a Straight Leg Canopy Tent.
另外一个人完成了本指南。
Virginia Gonzalez
于01/28/17注册
146 声望
撰写一个指南
团队
一条评论
where do you buy the leg from?
MK604CB - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 3,413
