跳转到主内容
Stove Element Receptacle Replacement
你所需要的
  1. Stove Element Receptacle Replacement, Stove Element Receptacle: 步骤 1 中的图像 1,3 Stove Element Receptacle Replacement, Stove Element Receptacle: 步骤 1 中的图像 2,3 Stove Element Receptacle Replacement, Stove Element Receptacle: 步骤 1 中的图像 3,3
    • First, locate the the gas safety shut-off valve and turn off the power supply.
    • Remove the pitted scorched burner.
    • Remove the drip tray after removing the pitted scorched burner.
  2. Stove Element Receptacle Replacement: 步骤 2 中的图像 1,3 Stove Element Receptacle Replacement: 步骤 2 中的图像 2,3 Stove Element Receptacle Replacement: 步骤 2 中的图像 3,3
    • Look for the receptacle mounting screw and loosen it with a screwdriver.
  3. Stove Element Receptacle Replacement: 步骤 3 中的图像 1,3 Stove Element Receptacle Replacement: 步骤 3 中的图像 2,3 Stove Element Receptacle Replacement: 步骤 3 中的图像 3,3
    • Pull the old receptacle block out and cut the receptacle block.
    • To strip the wires, place about an inch from the end of the wire into the mouth of the wire stripper. Carefully cut through the insulation without cutting through the copper wire.
    • With the mouth of the wire strippers still closed, pull the sheathing off to the end of the wire.
  4. Stove Element Receptacle Replacement: 步骤 4 中的图像 1,3 Stove Element Receptacle Replacement: 步骤 4 中的图像 2,3 Stove Element Receptacle Replacement: 步骤 4 中的图像 3,3
    • Assemble the new receptacle block by snapping the metal attachment to the terminal block.
    • Click the wires into the bottom opening of the terminal block.
    • Next, strip the end of the wires.
  5. Stove Element Receptacle Replacement: 步骤 5 中的图像 1,2 Stove Element Receptacle Replacement: 步骤 5 中的图像 2,2
    • Connect the new receptacle block to the wiring harness and secure it with twist connectors.
  6. Stove Element Receptacle Replacement: 步骤 6 中的图像 1,3 Stove Element Receptacle Replacement: 步骤 6 中的图像 2,3 Stove Element Receptacle Replacement: 步骤 6 中的图像 3,3
    • Install the new receptacle block and tighten the mounting screw securely to ensure proper grounding.
    • Put the drip tray back.
    • Then, put the pitted scorched burner back.
  7. Stove Element Receptacle Replacement: 步骤 7 中的图像 1,1
    • Turn on the power supply and check for proper operation.
结论
2等其他人完成本指南。
My Danh
于03/07/22注册
193 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 49
总计 1,069
