跳转到主内容
加入维修社区 - 创建账户
Stihl O25 Chain Replacement
你所需要的
  1. Stihl O25 Chain Replacement, Stihl O25 Chain: 步骤 1 中的图像 1,1
    • Be sure to turn off the chainsaw before servicing it.
    • Caution: Chainsaw blades are sharp. Wear protective gloves through the procedure.
    • Loosen the nuts on the chain cover with the wrench side of the scrench until the cover comes off of the saw.
  2. Stihl O25 Chain Replacement: 步骤 2 中的图像 1,1
    • Pull the chain and chainsaw bar off of the power head.
    • Pull the chain back to loosen off of the gears, and lift straight up.
  3. Stihl O25 Chain Replacement: 步骤 3 中的图像 1,1
    • Clean out the grooves on the chainsaw bar. This will help with the next step.
  4. Stihl O25 Chain Replacement: 步骤 4 中的图像 1,1
    • Make sure the chain is positioned correctly. If you are looking at the top of the saw, the chain rotates away from the operator.
    • Position the chain so the teeth face away on the top of the saw.
  5. Stihl O25 Chain Replacement: 步骤 5 中的图像 1,1
    • Place the bar and chain back onto the saw.
    • The bolt slot on the bar will slide onto the bolts on the saw.
    • The chain will go around the gear towards the back of the saw.
    • You may have to move the chain around to get it to fit properly.
  6. Stihl O25 Chain Replacement: 步骤 6 中的图像 1,2 Stihl O25 Chain Replacement: 步骤 6 中的图像 2,2
    • Tighten the chain by turning the tightening screw.
    • Insert the screwdriver end of the scrench into the screw and turn clockwise.
  7. Stihl O25 Chain Replacement: 步骤 7 中的图像 1,1
    • Chain tightness is often a preference of the chainsaw operator, but a good rule of thumb to follow is when you pull up on the chain, two chain links should come out of the bar grooves.
  8. Stihl O25 Chain Replacement: 步骤 8 中的图像 1,1
    • Put the cover back on and tighten the nuts down.
  9. Stihl O25 Chain Replacement: 步骤 9 中的图像 1,1
    • To sharpen the chain, mark one of the teeth with a pencil or sharpie.
  10. Stihl O25 Chain Replacement: 步骤 10 中的图像 1,1
    • Take a round file and place it on the cutting surface.
  11. Stihl O25 Chain Replacement: 步骤 11 中的图像 1,1
    • The file should be angled slighty upwards and follow the angle of the saw tooth.
    • Slide the file while applying pressure and twist slightly.
    • Teeth on a saw alternate which way they are facing.
    • Skip one tooth to continue to sharpen on the same side. Use the same number of file strokes on each tooth.
    • Continue to sharpen until you reach the original tooth that was marked. You can then sharpen the set of teeth facing the other way with the same process.
终点
2等其他人完成本指南。
Nathan Comar
于03/30/16注册
182 声望
撰写一个指南
团队
Michigan Tech, Team 1-3, Lauer Spring 2016 Michigan Tech, Team 1-3, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G3
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 77
总计 2,126
