本指南有最近更改,您可查看未经巡查的最新版本。
简介
Hello this guide is to be used for sticking keys on a saxophone; however, this guide should be used as a last resort if cleaning the pad on the key did not solve the problem. Most sticking keys can be solved easily by simply cleaning the pad, but in extreme cases it may be deemed necessary to loosen the key itself.
你所需要的
Loosen screw until key moves freely or as desired. Once as desired, you are then ready to play the instrument and test out key!
一条评论
An Issue I have with a sticky key on my Alto Saxophpone. I found a remedy on ifixit.com, a hack recommended for fixing pretty much anything! Try it out!!
kwiggins01 - 回复
