跳转到主内容
Steelseries Rival 700 Gaming Mouse Top cover Replacement
你所需要的
  1. Steelseries Rival 700 Gaming Mouse Top cover Replacement, Disconnect the mouse from your computer: 步骤 1 中的图像 1,2 Steelseries Rival 700 Gaming Mouse Top cover Replacement, Disconnect the mouse from your computer: 步骤 1 中的图像 2,2
    • To avoid electronically damaging either your computer or your mouse, unplug the usb cable from its socket.
  2. Steelseries Rival 700 Gaming Mouse Top cover Replacement, Disconnect the cable from the mouse: 步骤 2 中的图像 1,3 Steelseries Rival 700 Gaming Mouse Top cover Replacement, Disconnect the cable from the mouse: 步骤 2 中的图像 2,3 Steelseries Rival 700 Gaming Mouse Top cover Replacement, Disconnect the cable from the mouse: 步骤 2 中的图像 3,3
    • The Rival 700 mouse is a non wireless mouse. The micro-USB cable end is an elbow socket, secured by a plastic clip.
    • To disconnect the cable from the mouse, firmly press the plastic clip using your thumb
  3. Steelseries Rival 700 Gaming Mouse Top cover Replacement, Nameplate removal: 步骤 3 中的图像 1,2 Steelseries Rival 700 Gaming Mouse Top cover Replacement, Nameplate removal: 步骤 3 中的图像 2,2
    • The original nameplate is a soft rubber one that can be removed just by pulling it softly out of its socket.
    • WARNING: When reassembling, if you're using a custom nameplate that may not be as stretchable as the original one, insert it softly, and use a lime tool on the new part to avoid damaging the mouse socket.
  4. Steelseries Rival 700 Gaming Mouse Top cover Replacement, Nameplate printing: 步骤 4 中的图像 1,1
    • You will be able to download the 3D files to design a custom nameplate on the Steelseries website. The link is also provided in the part description.
    • On this picture, the original "RIVAL" nameplate will be replaced with a new one on which i just had my Twitch ID printed.
    • Be creative, use colored plastic, put logos and drawings on your mouse.
  5. Steelseries Rival 700 Gaming Mouse Top cover Replacement, Top cover removal: 步骤 5 中的图像 1,3 Steelseries Rival 700 Gaming Mouse Top cover Replacement, Top cover removal: 步骤 5 中的图像 2,3 Steelseries Rival 700 Gaming Mouse Top cover Replacement, Top cover removal: 步骤 5 中的图像 3,3
    • Use both your index and thumb to gently pry the top cover out from the mouse.
    • This part is a thin plastic one which needs a certain amount of strength to be removed. Be careful not to break it.
  6. Steelseries Rival 700 Gaming Mouse Top cover Replacement, Top cover replacement: 步骤 6 中的图像 1,1
    • Steelseries sells a set of two different covers to replace the original one, with a sweat-resistant one f.e.
    • Check the parts section for the purchase link.
    • On the left, you can see on the wide led slot that is used to color the Steelseries logo on your mouse.
结论
3等其他人完成本指南。
Vincent Monteil
于07/06/13注册
6,975 声望
创作了19篇指南
2条评论
Very nice, clean guide. Now if someone could just tell them how to get more games to support the OLED and the tactile response thingy, and how to freaking add this guide to the manual since they use all of it to sell what is basically a very basic, but quite competent mouse with some still very useless gimmicks.
Ulrik Borg - 回复
Hey Ulrik ! Thank you very much ! :)
I already had an investigation about this. Looks like it is an "open" framework. But using it requires a given amount of extra dev, plus a potential advantage for players who have this mouse compared to the other ones, and that's why there are so few games supported... :/
I'm as sad as you. Was hoping to have LoL, Overwatch and so on supported but...
Vincent Monteil -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 22
总计 2,684
