简介
If your SteelSeries Stratus XL is having issues with it’s L2 or R2 trigger, use this guide to allow proper function to your controller.
Your controller triggers are activated with a spring and a screw from an arm pot together on the inside. You may need to do some minor adjustments to the screw on the inside along with some lubing using some isopropyl alcohol for the arm socket.
Be sure to fully disconnect and power off your controller before starting your work.
你所需要的
Remove the battery cover and the batteries from the controller.
即将完成!
To reassemble your device, follow the instructions in reverse order.
结论
