跳转到主内容
加入维修社区 - 创建账户
SteelSeries Nimbus+ Mainboard Replacement
你所需要的
  1. SteelSeries Nimbus+ Mainboard Replacement, Remove the phone mount: 步骤 1 中的图像 1,2 SteelSeries Nimbus+ Mainboard Replacement, Remove the phone mount: 步骤 1 中的图像 2,2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. SteelSeries Nimbus+ Mainboard Replacement, Remove the sticker: 步骤 2 中的图像 1,1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the back cover: 步骤 3 中的图像 1,1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: 步骤 4 中的图像 1,2 SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: 步骤 4 中的图像 2,2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: 步骤 5 中的图像 1,2 SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: 步骤 5 中的图像 2,2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: 步骤 6 中的图像 1,2 SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: 步骤 6 中的图像 2,2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: 步骤 7 中的图像 1,2 SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: 步骤 7 中的图像 2,2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: 步骤 8 中的图像 1,3 SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: 步骤 8 中的图像 2,3 SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: 步骤 8 中的图像 3,3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: 步骤 9 中的图像 1,3 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: 步骤 9 中的图像 2,3 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. SteelSeries Nimbus+ Mainboard Replacement, Remove the back cover assembly: 步骤 10 中的图像 1,1
    • Remove the back cover assembly.
  11. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the board: 步骤 11 中的图像 1,1
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
  12. SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: 步骤 12 中的图像 1,3 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: 步骤 12 中的图像 2,3 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: 步骤 12 中的图像 3,3
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
  13. SteelSeries Nimbus+ Mainboard Replacement, Remove the board: 步骤 13 中的图像 1,1
    • Remove the board with the thumbsticks from the mainboard.
  14. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the mainboard: 步骤 14 中的图像 1,1
    • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
  15. SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: 步骤 15 中的图像 1,3 SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: 步骤 15 中的图像 2,3 SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: 步骤 15 中的图像 3,3
    • Use your fingers to lift up the mainboard from the front case.
    • Remove the mainboard.
  16. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the triggers: 步骤 16 中的图像 1,1
    • Use a Phillips screwdriver to remove the four screws securing the triggers on the motherboard.
  17. SteelSeries Nimbus+ Mainboard Replacement, Release the right trigger: 步骤 17 中的图像 1,2 SteelSeries Nimbus+ Mainboard Replacement, Release the right trigger: 步骤 17 中的图像 2,2
    • Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
  18. SteelSeries Nimbus+ Mainboard Replacement, Release the left trigger: 步骤 18 中的图像 1,2 SteelSeries Nimbus+ Mainboard Replacement, Release the left trigger: 步骤 18 中的图像 2,2
    • Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
  19. SteelSeries Nimbus+ Mainboard Replacement, Remove the mainboard: 步骤 19 中的图像 1,1
    • Compare your new mainboard with the original mainboard. It may be necessary to transfer over some components. For this, you may have to unsolder the trigger buttons or attach the rubber covers to the new mainboard.
结论
Adriana Zwink
于12/18/19注册
63,660 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
125 名成员
创作了24,046篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 62
总计 465
