跳转到主内容
SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement
你所需要的
  1. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Ear Cushions: 步骤 1 中的图像 1,2 SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Ear Cushions: 步骤 1 中的图像 2,2
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Circuit Board: 步骤 2 中的图像 1,1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
结论
7等其他人完成本指南。
Kyle Chang
于01/24/19注册
1,152 声望
创作了7篇指南
团队
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019 的会员
CPSU-WHITE-W19S18G1
4 名成员
创作了21篇指南
3条评论
any idea where i can buy the circuit parts to both side?
erminio santiago - 回复
any idea where i can buy Circuit Board Replacement for both side? please
What's the problem that requires circuit board replacement? My left speaker doesn't work checked and all wires connected. Wondering if the circuit board fixes that
bayarea_rooter - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 16
过去 30 天: 56
总计 9,396
