跳转到主内容
SteelSeries Apex 64145 USB Port Connector Replacement
你所需要的
  1. SteelSeries Apex 64145 USB Port Connector Replacement, Gel Membrane: 步骤 1 中的图像 1,1
    • Unplug the keyboard from the computer.
  2. SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 2 中的图像 1,1
    • Unscrew the twenty black 4.5 mm Phillips #1 screws on the back of the keyboard.
  3. SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 3 中的图像 1,1
    • Pry open the back of the keyboard.
  4. SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 4 中的图像 1,2 SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 4 中的图像 2,2
    • Remove the gel membrane.
  5. SteelSeries Apex 64145 USB Port Connector Replacement, LED: 步骤 5 中的图像 1,2 SteelSeries Apex 64145 USB Port Connector Replacement, LED: 步骤 5 中的图像 2,2
    • Unscrew the two silver 4.0 mm Phillips #1 screws and the three black 6.5 mm Phillips #1 screws holding the silicone sheets.
  6. SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 6 中的图像 1,1
    • Flip the chip slightly in order to remove the sheets.
  7. SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 7 中的图像 1,1
    • Remove the sheets.
  8. SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 8 中的图像 1,2 SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 8 中的图像 2,2
    • Unscrew the two silver 4.5 mm Phillips #1 screws and the seven 5.0 mm Phillips #1 screws that deter the plastic panel from removal.
  9. SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 9 中的图像 1,1
    • Remove the plastic panel and the white sheet.
  10. SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 10 中的图像 1,3 SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 10 中的图像 2,3 SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 10 中的图像 3,3
    • Unplug the wires connected to the LEDs.
  11. SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 11 中的图像 1,2 SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 11 中的图像 2,2
    • Remove the LEDs.
  12. SteelSeries Apex 64145 USB Port Connector Replacement, USB Port Connector: 步骤 12 中的图像 1,1
    • Unscrew the two 4.5 mm silver Phillips #1 screws that hold the USB port connector.
  13. SteelSeries Apex 64145 USB Port Connector Replacement: 步骤 13 中的图像 1,1
    • Unplug the wires and remove the USB port connector.
结论
2等其他人完成本指南。
Zwe Phone Shein
于02/28/17注册
559 声望
创作了5篇指南
团队
USF Tampa, Team S1-G1, Nance Spring 2017 USF Tampa, Team S1-G1, Nance Spring 2017 的会员
USFT-NANCE-S17S1G1
4 名成员
创作了10篇指南
2条评论
the 2 usb in the keyboard what amp are they running on.. 500mA ? I hope for 1500-2000 mA
And what standard are they ? USB3 ??
Simon Sundström - 回复
can the other part be replaced too. like the power board ?
i think i have a powerboard problem and if I can replace it that would be awesome, as I love my keyboard and im
very very attached to it. I was playing a video game, nothing too harsh , and the lights went out and poof it never came back. never had a problem with this keyboard until 2 and a 1/2 years later that it did this. Its in a non-smoking room and gaming studio always kept very clean.
I would love to fix it to bring it back to life.
Twsted - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 55
总计 3,037
