跳转到主内容
SteelSeries Apex 3 TKL USB Port Replacement
你所需要的
  1. SteelSeries Apex 3 TKL USB Port Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Use a JIS #00 screwdriver to remove all back panel screws.
  2. SteelSeries Apex 3 TKL USB Port Replacement: 步骤 2 中的图像 1,2 SteelSeries Apex 3 TKL USB Port Replacement: 步骤 2 中的图像 2,2
    • Use the iFixit opening pick to pry open the back panel by running it along the edges of the keyboard.
  3. SteelSeries Apex 3 TKL USB Port Replacement, USB Port: 步骤 3 中的图像 1,1
    • Release the ribbon wire connections using the metal spudger which has a more rigid tip for undoing the clips.
  4. SteelSeries Apex 3 TKL USB Port Replacement: 步骤 4 中的图像 1,1
    • Use a JIS #00 screwdriver to remove the USB port cover.
  5. SteelSeries Apex 3 TKL USB Port Replacement: 步骤 5 中的图像 1,1
    • Flip the motherboard over and carefully use the spudger to push out the connecting wire.
结论
Use your new USB port insert back into the motherboard. To reassemble your device, follow these instructions in reverse order.
Tyler Pepe
于03/20/24注册
169 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-3, Santin Spring 2024 UMass Dartmouth, Team 1-3, Santin Spring 2024 的会员
UMASSD-SANTIN-S24S1G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 24
