跳转到主内容
Steam iron - Step 1: The different functions
  1. Steam iron - Step 1: The different functions, What are the functions of a steam iron?: 步骤 1 中的图像 1,1
    • The name iron comes from the actual metal that the appliance is made from. The shape of the iron, pointed at its tip, allows you to iron all the corners of the clothes, while its weight smoothes the fabric.
    • The part of the iron that makes direct contact with the fabric is called the "sole (plate)". In order for the iron to be effective, the device needs to be heated. This iron also makes use of a steam system, which makes it possible to moisten the fabric while ironing.
    • Ironing helps loosen the bonds between the long chains of molecules that make up polymer fiber materials. The heat and weight of the iron stretches the fibers while the fabric retains its new shape once it's cooled. Some materials, like cotton, require the use of water to loosen intermolecular bonds.
    • Information about steam irons
    • Information (2) on steam irons
    • Wikipedia link - Clothes iron
  2. Steam iron - Step 1: The different functions, Device description: 步骤 2 中的图像 1,2 Steam iron - Step 1: The different functions, Device description: 步骤 2 中的图像 2,2
    • The iron rests on a reservoir with a heat-resistant base.
    • At the front of the water tank, a removable spout serves as a funnel to allow a user to fill the reservoir with water (1.7l)
    • There is a button on the top of the device, which locks the iron to the reservoir base.
    • At the rear is a control panel made up of three buttons.
  3. Steam iron - Step 1: The different functions, Device controls: 步骤 3 中的图像 1,3 Steam iron - Step 1: The different functions, Device controls: 步骤 3 中的图像 2,3 Steam iron - Step 1: The different functions, Device controls: 步骤 3 中的图像 3,3
    • The control panel has three buttons. Middle button = On/Off, Left button = Eco Mode, Right button = Anti-limescale function
    • The middle button: allows the iron to operate with a short press. When the button is pressed a steady blue light comes on. After approximately 2 minutes, the appliance beeps to signal that the selected temperature has been reached and the iron is ready for use.
    • A long press on this button while ironing switches to "Turbo" mode. The iron generates more steam, and the blue light turns white.
    • Left button: pressing this button while ironing both decreases the volume of steam and the temperature of the iron.
    • Right button: This functions to help prevent lime deposits. Place the iron on an appropriate container to collect the resultant steam. Then press this button; the iron will generate steam continuously for 2 minutes in Turbo mode.
    • The button to send steam to the sole is located on the handle of the iron. This button is equipped with a light which flashes on start-up until operating temperature is reached, then glows steadily.
结论
We now know what an XL reservoir steam iron is and what these different features are. We can move on to studying how it works in the following tutorial: "How does it work?"
3等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Atelier Soudé
于12/13/18注册
4,642 声望
创作了18篇指南
团队
Atelier Soudé Atelier Soudé 的会员
Local Repair Groups
5 名成员
创作了43篇指南
3指南评论
All botton is making flasher and dont work
abbas Taqi - 回复
abbas Taqi - 回复
Why doesn't the iron produce steam?
Taher Shoa - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 136
总计 6,697
