跳转到主内容
Starbucks Barista Steam Wand replacement or cleaning
你所需要的
  1. Starbucks Barista Steam Wand replacement or cleaning, steam wand: 步骤 1 中的图像 1,1
    • Using a wrench, unscrew the hex nut and remove the steam wand.
    • Note: Do not lose the hex nut once it is unscrewed.
  2. Starbucks Barista Steam Wand replacement or cleaning: 步骤 2 中的图像 1,2 Starbucks Barista Steam Wand replacement or cleaning: 步骤 2 中的图像 2,2
    • Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material.
    • Place the steam wand in a de-calcifying solution as directed by product.
    • Reconnect the steam wand.
    • See the links section of the device page to purchase a new steam wand.
结论
4等其他人完成本指南。
David
于01/28/11注册
739 声望
创作了3篇指南
团队
Cal Poly, Team 4-42, Regan Winter 2011 Cal Poly, Team 4-42, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G42
4 名成员
创作了5篇指南
一条评论
To replace steam-wand seals (in case of water leaking out from the center of the steam-wand): https://www.youtube.com/watch?v=fulyy9A9... , but note - for parts: https://philips.encompass.com/model/SAER... (worth going to amazon.de and entering the partnumbers into the search box: e.g. the o-rings for the needle-valve (996530013462)
R Cly - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 15,852
