简介
The ready light is a simple LED that shows when the Barista has heated up to its needed temperature. This LED may burn out or its connectors may loosen.
你所需要的
Locate the ready light.
Gently push the fixture against the Barista wall.
Pull the fixture straight up to release it.
Note: The fixture works as a spring.
Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
Disconnect the wire lead connectors.
Remove the ready light unit (fixture).
另外一个人完成了本指南。
4指南评论
Beee2smoove.
Rich Ridout - 回复 分享
Youth and sports for
Rich Ridout - 回复 分享
Ttuii addinsists
Rich Ridout - 回复 分享
