跳转到主内容
Starbucks Barista Ready Light Replacement
你所需要的
  1. Starbucks Barista Ready Light Replacement, Ready Light: 步骤 1 中的图像 1,2 Starbucks Barista Ready Light Replacement, Ready Light: 步骤 1 中的图像 2,2
    • Unscrew the 6 screws from the back panel.
    • Remove the back panel.
  2. Starbucks Barista Ready Light Replacement: 步骤 2 中的图像 1,3 Starbucks Barista Ready Light Replacement: 步骤 2 中的图像 2,3 Starbucks Barista Ready Light Replacement: 步骤 2 中的图像 3,3
    • Locate the ready light.
    • Gently push the fixture against the Barista wall.
    • Pull the fixture straight up to release it.
    • Note: The fixture works as a spring.
    • Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
    • Disconnect the wire lead connectors.
    • Remove the ready light unit (fixture).
  3. Starbucks Barista Ready Light Replacement: 步骤 3 中的图像 1,1
    • Replace the old LED with a new LED.
    • To put back, match the green cover to the slot of the LED fixture, then slide the fixture down against the barista wall.
结论
另外一个人完成了本指南。
David
于01/28/11注册
739 声望
创作了3篇指南
团队
Cal Poly, Team 4-42, Regan Winter 2011 Cal Poly, Team 4-42, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G42
4 名成员
创作了5篇指南
4条评论
Youth and sports for
Rich Ridout - 回复
Ttuii addinsists
Rich Ridout - 回复
Where can I get a new LED bulb?
Paula - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 6,097
