当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
Using the plastic opening tool, remove the back plastic feet.
After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
Carefully pull apart the bottom panel from the top panel.
Be careful not to pull too forcefully as the panels are connected by wires.
Beware of pencil shavings falling out onto your workspace.
Gently pry the first gear out of the gear housing with a spudger.
To ease reassembly, note the orientation of the gear as you pry it free.
Gently pry the second gear out of the gear housing with a spudger.
To ease reassembly, note the orientation of the gear before you pry it free.
Gently pry the third gear out of the housing with a spudger.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
