跳转到主内容
Staples 34462 Electric Pencil Sharpener Cutter Replacement
你所需要的
  1. Staples 34462 Electric Pencil Sharpener Cutter Replacement, Cover: 步骤 1 中的图像 1,1
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 步骤 2 中的图像 1,1
    • Turn the pencil sharpener on its side.
  3. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 步骤 4 中的图像 1,1
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 步骤 6 中的图像 1,1
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  7. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 步骤 7 中的图像 1,1
    • Carefully pull the cover from the top panel and set it aside.
  8. Staples 34462 Electric Pencil Sharpener Cutter Replacement, Cutter: 步骤 8 中的图像 1,1
    • Orient the top panel so that the sensor bracket is facing you.
    • Using a Phillips00 screwdriver, remove four 10.42mm screws.
    • Using a Phillips00 screwdriver, remove two 6.96mm screws.
  9. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 步骤 9 中的图像 1,1
    • Pull out the outside cover to remove it from the cutter chamber and set them side by side.
  10. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 步骤 10 中的图像 1,1
    • Carefully pull the cutter out of the cutter chamber.
    • Beware of pencil shavings and debris.
结论
另外一个人完成了本指南。
4条评论
Very clear, easy to follow. Nice photos.
uccbill - 回复
where can I get a replacement cutter?
Mel Buchanan - 回复
Did you find replacement blades?
Horace M Hargroves -
Absolutely great directions. However I lost the two 10.3mm screws somewhere along the line - I did not go any further at that point. I will check out replacement cutters and see if I want to pursue or purchase new. I believe this was my work stapler of the 80's.
Leslie H - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 33
总计 2,458
