跳转到主内容
Staples 34462 Electric Pencil Sharpener Cover
你所需要的
  1. Staples 34462 Electric Pencil Sharpener Cover, Cover: 步骤 1 中的图像 1,1
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Staples 34462 Electric Pencil Sharpener Cover: 步骤 2 中的图像 1,1
    • Turn the pencil sharpener on its side.
  3. Staples 34462 Electric Pencil Sharpener Cover: 步骤 3 中的图像 1,1
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Staples 34462 Electric Pencil Sharpener Cover: 步骤 4 中的图像 1,1
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Staples 34462 Electric Pencil Sharpener Cover: 步骤 5 中的图像 1,1
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Staples 34462 Electric Pencil Sharpener Cover: 步骤 6 中的图像 1,1
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  7. Staples 34462 Electric Pencil Sharpener Cover: 步骤 7 中的图像 1,1
    • Carefully pull the cover from the top panel and set it aside.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 865
