跳转到主内容
Stanley ST-222A-120 Pressure Sensor Replacement
  1. Stanley ST-222A-120 Pressure Sensor Replacement, Pressure Sensor: 步骤 1 中的图像 1,1
    • Unplug the heater for safety during your repair.
  2. Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 2 中的图像 1,3 Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 2 中的图像 2,3 Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 2 中的图像 3,3
    • With your hands gently remove the plastic covers on either side of the heater.
  3. Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 3 中的图像 1,2 Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 3 中的图像 2,2
    • Use your hands to pry apart the plastic halves of the heater to see the internals of the device.
  4. Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 4 中的图像 1,2 Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 4 中的图像 2,2
    • Locate small pressure sensor replacement and small pressure pin at the bottom of the device.
  5. Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 5 中的图像 1,2 Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 5 中的图像 2,2
    • Use your hands to help guide the pressure pin back into a position where the replacement plate can slide back onto it.
    • Needle nose pliers may be a good assistant in this situation.
  6. Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 6 中的图像 1,2 Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 6 中的图像 2,2
    • While the plastic is open hold the pin out with a finger.
    • Line up the pressure plate to the pressure pin.
  7. Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 7 中的图像 1,2 Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 7 中的图像 2,2
    • Gently put the pressure plate back onto the pressure pin.
  8. Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 8 中的图像 1,3 Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 8 中的图像 2,3 Stanley ST-222A-120 Pressure Sensor Replacement: 步骤 8 中的图像 3,3
    • Carefully press the plastic back together.
    • Be conscious not to interrupt the placement of the newly repaired pressure plate.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 535
