跳转到主内容
Stanley 10-079 Box Cutter Blade Replacement
你所需要的
  1. Stanley 10-079 Box Cutter Blade  Replacement, Knife Blade: 步骤 1 中的图像 1,1
    • Here is the knife we will be replacing the blade on, its a Stanley 10-079 Box Cutter.
  2. Stanley 10-079 Box Cutter Blade  Replacement: 步骤 2 中的图像 1,1
    • Using a screwdriver or a coin remove the single screw in the center of the box cutter
  3. Stanley 10-079 Box Cutter Blade  Replacement: 步骤 3 中的图像 1,1
    • Carefully pull up on the top half of the cutter exposing the blade on the inside.
  4. Stanley 10-079 Box Cutter Blade  Replacement: 步骤 4 中的图像 1,1
    • carefully without cutting yourself lift the old blade out this should require no force.
  5. Stanley 10-079 Box Cutter Blade  Replacement: 步骤 5 中的图像 1,1
    • with the old blade out replace it with a new blade from the back or one that was purchased separately.
  6. Stanley 10-079 Box Cutter Blade  Replacement, Reassembly: 步骤 6 中的图像 1,2 Stanley 10-079 Box Cutter Blade  Replacement, Reassembly: 步骤 6 中的图像 2,2
    • With the fresh blade in place carefully place the upper half of the box cutter on the lower half that contains the blade as shown in image number 2.
  7. Stanley 10-079 Box Cutter Blade  Replacement, Final Assembily: 步骤 7 中的图像 1,1
    • insert the screw you first removed back into the hole in the center ensuring that you tighten it down not too tight to get undone without a power tool
  8. Stanley 10-079 Box Cutter Blade  Replacement: 步骤 8 中的图像 1,1
    • With the center screw re-installed you are all set to use your Stanley 10-079 box cutter again with a brand new blade.
结论
You are all set and ready to use your brand new installed blade! Here are some replacement blades that I found on amazon. https://www.amazon.com/Stanley-11-921L-5...
2等其他人完成本指南。
Michael Cawley
于10/11/17注册
184 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 56
总计 6,622
