跳转到主内容
Stagg Electro-Acoustic Guitar Strings Replacement
你所需要的
  1. Stagg Electro-Acoustic Guitar Strings Replacement, Guitar Strings: 步骤 1 中的图像 1,1
    • Place the string winder on the tuning key.
  2. Stagg Electro-Acoustic Guitar Strings Replacement: 步骤 2 中的图像 1,1
    • Wind up the string winder counter-clockwise to loosen the strings.
  3. Stagg Electro-Acoustic Guitar Strings Replacement: 步骤 3 中的图像 1,1
    • With the string clipper, clip the string under the neck of the guitar.
  4. Stagg Electro-Acoustic Guitar Strings Replacement: 步骤 4 中的图像 1,1
    • Unwind the string from the machine head and remove it.
  5. Stagg Electro-Acoustic Guitar Strings Replacement: 步骤 5 中的图像 1,1
    • With the string winder pop the string peg out of its hole.
  6. Stagg Electro-Acoustic Guitar Strings Replacement: 步骤 6 中的图像 1,1
    • Place the colored circle end of the string in the peg hole.
  7. Stagg Electro-Acoustic Guitar Strings Replacement: 步骤 7 中的图像 1,1
    • Put the peg in the hole with the string.
    • Pull the string while pushing the pin in.
  8. Stagg Electro-Acoustic Guitar Strings Replacement: 步骤 8 中的图像 1,1
    • Precut the other side of the string by one and a half machine heads.
  9. Stagg Electro-Acoustic Guitar Strings Replacement: 步骤 9 中的图像 1,1
    • Thread the string through the peg.
    • Wind the string clockwise from top to bottom with the string winder.
    • Do not overlap the string when winding it.
结论
Repeat steps for each string.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 395
