当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Unwind the strings by turning the tuning pegs.
Pull the strings out of the tuning peg holes.
Push the strings out through the back plate holes.
Use a string winder to speed up this process.
Lift up the pickup guard gently.
Flip the pickup guard to expose the wiring.
Place a towel underneath the pickup guard to protect your guitar's body.
Potential for device damage: Do not use excessive force when lifting the pickup guard.
Take note of where each pickup is wired.
Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
Pickups are usually wired to the potentiometers and pickup selector switch.
Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
Desolder the pickups from the potentiometers.
Potential for device damage: Excessive heat from the soldering iron can damage components.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
