跳转到主内容
Squier Strat Guitar Pickups Replacement
你所需要的
  1. Squier Strat Guitar Pickups Replacement, Pickups: 步骤 1 中的图像 1,3 Squier Strat Guitar Pickups Replacement, Pickups: 步骤 1 中的图像 2,3 Squier Strat Guitar Pickups Replacement, Pickups: 步骤 1 中的图像 3,3
    • Unwind the strings by turning the tuning pegs.
    • Pull the strings out of the tuning peg holes.
    • Push the strings out through the back plate holes.
    • Use a string winder to speed up this process.
  2. Squier Strat Guitar Pickups Replacement: 步骤 2 中的图像 1,2 Squier Strat Guitar Pickups Replacement: 步骤 2 中的图像 2,2
    • Remove the 11 screws holding the pickguard to the body of the guitar.
  3. Squier Strat Guitar Pickups Replacement: 步骤 3 中的图像 1,3 Squier Strat Guitar Pickups Replacement: 步骤 3 中的图像 2,3 Squier Strat Guitar Pickups Replacement: 步骤 3 中的图像 3,3
    • Lift up the pickup guard gently.
    • Flip the pickup guard to expose the wiring.
    • Place a towel underneath the pickup guard to protect your guitar's body.
    • Potential for device damage: Do not use excessive force when lifting the pickup guard.
  4. Squier Strat Guitar Pickups Replacement: 步骤 4 中的图像 1,2 Squier Strat Guitar Pickups Replacement: 步骤 4 中的图像 2,2
    • Take note of where each pickup is wired.
    • Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
    • Pickups are usually wired to the potentiometers and pickup selector switch.
  5. Squier Strat Guitar Pickups Replacement: 步骤 5 中的图像 1,2 Squier Strat Guitar Pickups Replacement: 步骤 5 中的图像 2,2
    • Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
    • Desolder the pickups from the potentiometers.
    • Potential for device damage: Excessive heat from the soldering iron can damage components.
  6. Squier Strat Guitar Pickups Replacement: 步骤 6 中的图像 1,2 Squier Strat Guitar Pickups Replacement: 步骤 6 中的图像 2,2
    • Flip the pickup guard back to its original position.
    • Remove the screws holding the pickups to the pickup guard.
  7. Squier Strat Guitar Pickups Replacement: 步骤 7 中的图像 1,2 Squier Strat Guitar Pickups Replacement: 步骤 7 中的图像 2,2
    • Flip the pickup guard to reveal the wiring.
    • Remove the pickups from the pickup guard. They should come out very easily.
结论
4等其他人完成本指南。
Ion
于09/29/15注册
479 声望
创作了3篇指南
团队
Cal Poly, Team 10-5, Green Fall 2015 Cal Poly, Team 10-5, Green Fall 2015 的会员
CPSU-GREEN-F15S10G5
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 24
过去 30 天: 88
总计 6,473
