跳转到主内容
Spy Gear Video Walkie Talkies Camera Replacement
你所需要的
  1. Spy Gear Video Walkie Talkies Camera Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Remove the battery cover by removing the P1 Philips screw.
    • Remove the 3 AA batteries by hand.
  2. Spy Gear Video Walkie Talkies Camera Replacement: 步骤 2 中的图像 1,1
    • Unscrew Top Cover with a 3mm Triangle driver bit from the Driver Kit.
  3. Spy Gear Video Walkie Talkies Camera Replacement: 步骤 3 中的图像 1,1
    • Use Opening Tool to release barbed latch on top cover.
  4. Spy Gear Video Walkie Talkies Camera Replacement: 步骤 4 中的图像 1,1
    • Release pilot studs near the hinge with Metal Spudger.
  5. Spy Gear Video Walkie Talkies Camera Replacement: 步骤 5 中的图像 1,1
    • Once the Top Cover is free, you will have full access to the circuitry.
  6. Spy Gear Video Walkie Talkies Camera Replacement, Camera: 步骤 6 中的图像 1,1
    • Use Tweezers to remove the side button.
  7. Spy Gear Video Walkie Talkies Camera Replacement: 步骤 7 中的图像 1,2 Spy Gear Video Walkie Talkies Camera Replacement: 步骤 7 中的图像 2,2
    • Release the zero insertion force (ZIF) connector.
    • Pull the ribbon cable away carefully.
  8. Spy Gear Video Walkie Talkies Camera Replacement: 步骤 8 中的图像 1,1
    • With the ribbon cable free from obstructions, use a Prying Tool to release the circuit board from the guide studs.
  9. Spy Gear Video Walkie Talkies Camera Replacement: 步骤 9 中的图像 1,1
    • With a plastic Prying Tool, separate the screen from the mounting tray.
    • Adhesive between the layers may provoke damage to the screen or tray. Take your time.
  10. Spy Gear Video Walkie Talkies Camera Replacement: 步骤 10 中的图像 1,1
    • Once the screen is completely folded away from the mounting tray, release it from the circuit board by hand.
  11. Spy Gear Video Walkie Talkies Camera Replacement: 步骤 11 中的图像 1,1
    • Release the back of the mounting tray using a plastic Pick to unhook the barb from the circuit board.
  12. Spy Gear Video Walkie Talkies Camera Replacement: 步骤 12 中的图像 1,1
    • Now remove the mounting tray complete with camera and ribbon cable attached by sliding away from the screen.
    • You must not damage the screen or screen ribbon cable in this step.
  13. Spy Gear Video Walkie Talkies Camera Replacement: 步骤 13 中的图像 1,1
    • Discard faulty camera and mounting tray.
结论
2等其他人完成本指南。
James French
于02/15/16注册
151 声望
撰写一个指南
团队
IUPUI, Team 7-7, Wilson Spring 2016 IUPUI, Team 7-7, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S7G7
5 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 11
总计 670
