跳转到主内容
Sprout Channel Cubby Battery Replacement
你所需要的
  1. Sprout Channel Cubby Battery Replacement, Dissasemble the device: 步骤 1 中的图像 1,2 Sprout Channel Cubby Battery Replacement, Dissasemble the device: 步骤 1 中的图像 2,2
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Sprout Channel Cubby Battery Replacement, Battery: 步骤 2 中的图像 1,2 Sprout Channel Cubby Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Remove the black electrical tape over the ribbon connector.
    • Remove the ribbon connector over the battery.
    • Make sure to be careful of the ribbon connector while working on the device.
  3. Sprout Channel Cubby Battery Replacement: 步骤 3 中的图像 1,1
    • Next you must heat up the battery to help weaken the adhesive connecting the battery to the device.
  4. Sprout Channel Cubby Battery Replacement: 步骤 4 中的图像 1,1
    • Once this is done start to pry the battery away from the device carefully. It helps to start at the corners and move inward.
  5. Sprout Channel Cubby Battery Replacement: 步骤 5 中的图像 1,2 Sprout Channel Cubby Battery Replacement: 步骤 5 中的图像 2,2
    • Once you remove the battery from the device it is still connected by three wires: red, black, and, white. It is important to remember the order they are in when reconnecting the new battery.
结论
3等其他人完成本指南。
jasen biggins
于08/26/15注册
741 声望
创作了5篇指南
团队
USF Tampa, Team 14-101, Meier Fall 2015 USF Tampa, Team 14-101, Meier Fall 2015 的会员
USFT-MEIER-F15S14G101
4 名成员
创作了12篇指南
7条评论
Ours is only 6 months old. It only works when it stays plugged in. Battery is bad?
Rachel - 回复
I had the same problem, only played while plugged in and would not charge.. I found that the battery wires while appearing tight one wire had broken inside the wire insulation at the solder pad on the main board. When I redid the connection it charges, and works well. 8/11/16
larrywb135 -
My grand daughters won't come on, should I take it to an electronic store?. I don't want to try and pry it open, for fear I may make it worse, she loves her tablet, and it is very helpful for her with school, she's had it 2 years and I put it away for about 8 month, for going on line, without permission, I gave it back in Sept. Now its not charging or coming on. Thank you.Deborah
jacksondebo2010 - 回复
Where can I get a battery?
crzyinind - 回复
You can get one at Amazon, EBay and more.
Liu Woods -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 3,573
