跳转到主内容
Sprint Sanyo RL-4920 Vibrator Motor Replacement
你所需要的
  1. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Back of Phone: 步骤 1 中的图像 1,1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Remove Battery Pack: 步骤 2 中的图像 1,2 Sprint Sanyo RL-4920 Vibrator Motor Replacement, Remove Battery Pack: 步骤 2 中的图像 2,2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Screws: 步骤 3 中的图像 1,2 Sprint Sanyo RL-4920 Vibrator Motor Replacement, Screws: 步骤 3 中的图像 2,2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Separate Cases: 步骤 4 中的图像 1,1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Separate Cases: 步骤 5 中的图像 1,1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Vibrator Motor Replacement, The Front Case: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Display: 步骤 7 中的图像 1,2 Sprint Sanyo RL-4920 Vibrator Motor Replacement, Display: 步骤 7 中的图像 2,2
    • Locate the 4 white clips of the dispaly.
  8. Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 8 中的图像 1,2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 8 中的图像 2,2
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
  9. Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 9 中的图像 1,2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 9 中的图像 2,2
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
  10. Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 10 中的图像 1,2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 10 中的图像 2,2
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
  11. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Vibrator Motor: 步骤 11 中的图像 1,1
    • Use a Phillips-head screw bit to remove the screw under the yellow film
  12. Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 12 中的图像 1,3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 12 中的图像 2,3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 12 中的图像 3,3
    • Use the spudger tool to pry the latches ways from the circuit board
    • Detach the metal casing from the circuit board
  13. Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 13 中的图像 1,2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 13 中的图像 2,2
    • Remove wires attaching vibrator motor to circuit board gently so as not to damage them
  14. Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 14 中的图像 1,3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 14 中的图像 2,3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 14 中的图像 3,3
    • Once the metal casing is removed from the circuit board take it and locate the vibrator motor on the top side of the casing
    • Use the spudger tool to gently pry the vibrator motor out of its protective shell
  15. Sprint Sanyo RL-4920 Vibrator Motor Replacement: 步骤 15 中的图像 1,1
    • With the vibrator motor completely removed, you can now replace it with a new one
结论
另外一个人完成了本指南。
Austin Shores
于10/18/13注册
301 声望
创作了3篇指南
团队
Clemson, Team 13-5, Benson Fall 2013 Clemson, Team 13-5, Benson Fall 2013 的会员
CLEM-BENSON-F13S13G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 288
