跳转到主内容
Sprint Sanyo RL-4920 Speaker Replacement
你所需要的
  1. Sprint Sanyo RL-4920 Speaker Replacement, Back of Phone: 步骤 1 中的图像 1,1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Speaker Replacement, Remove Battery Pack: 步骤 2 中的图像 1,2 Sprint Sanyo RL-4920 Speaker Replacement, Remove Battery Pack: 步骤 2 中的图像 2,2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Speaker Replacement, Screws: 步骤 3 中的图像 1,2 Sprint Sanyo RL-4920 Speaker Replacement, Screws: 步骤 3 中的图像 2,2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Speaker Replacement, Separate Cases: 步骤 4 中的图像 1,1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Speaker Replacement, Separate Cases: 步骤 5 中的图像 1,1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Speaker Replacement, The Front Case: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Speaker Replacement, Screws: 步骤 7 中的图像 1,2 Sprint Sanyo RL-4920 Speaker Replacement, Screws: 步骤 7 中的图像 2,2
    • Locate the three screws securing the speaker.
    • Use a Phillips-head screw bit to unscrew the screws
  8. Sprint Sanyo RL-4920 Speaker Replacement, Replace Speaker: 步骤 8 中的图像 1,1
    • Remove the speaker.
    • Replace with new speaker.
    • Secure new speaker with screws and reassemble phone.
结论
Austin Shores
于10/18/13注册
301 声望
创作了3篇指南
团队
Clemson, Team 13-5, Benson Fall 2013 Clemson, Team 13-5, Benson Fall 2013 的会员
CLEM-BENSON-F13S13G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 8
总计 160
