配件
无需配件。
  1. Flip the phone over so that the screen is facing down.
    • Flip the phone over so that the screen is facing down.
  2. Push the gray lever up towards the top of the phone. Pull up on the battery pack and completely separate it from the phone.
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Locate the 5 screws around the back casing. Use a three-prong screw bit to remove all 5 screws
    • Locate the 5 screws around the back casing.
    • Use a three-prong screw bit to remove all 5 screws
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  6. Separate the two cases.
    • Separate the two cases.
  7. Use the plastic opening tool to remove the motherboard from the front case.
    • Use the plastic opening tool to remove the motherboard from the front case.
  8. The plastic keys are attached to the back side of the front case. To remove the keys, pull the plastic piece out of the front case using the plastic opening tool.
    • The plastic keys are attached to the back side of the front case. To remove the keys, pull the plastic piece out of the front case using the plastic opening tool.
结论
另外一个人完成了本指南。
Katherine Rieck
于2013年10月18日注册
101 信誉积分
撰写一个指南
团队
Clemson, Team 13-5, Benson Fall 2013 Clemson, Team 13-5, Benson Fall 2013 的会员
CLEM-BENSON-F13S13G5
3 名成员
创作了12篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 68
