跳转到主内容
Spin Master Hatchimal Draggle Fur Replacement
你所需要的
  1. Spin Master Hatchimal Draggle Fur Replacement, Plastic Wing Replacement: 步骤 1 中的图像 1,1
    • lay the Hatchimal on its side.
  2. Spin Master Hatchimal Draggle Fur Replacement: 步骤 2 中的图像 1,1
    • Using the plastic opening tool, push in on the purple clip.
  3. Spin Master Hatchimal Draggle Fur Replacement: 步骤 3 中的图像 1,1
    • Pull the wing off of the hatchimal.
    • The wing should come off with little resistance.
  4. Spin Master Hatchimal Draggle Fur Replacement, Fur Replacement: 步骤 4 中的图像 1,2 Spin Master Hatchimal Draggle Fur Replacement, Fur Replacement: 步骤 4 中的图像 2,2
    • Cut the fur retaining zip-tie with a pair of scissors.
  5. Spin Master Hatchimal Draggle Fur Replacement: 步骤 5 中的图像 1,2 Spin Master Hatchimal Draggle Fur Replacement: 步骤 5 中的图像 2,2
    • Lift the fur up until it can't go further.
  6. Spin Master Hatchimal Draggle Fur Replacement: 步骤 6 中的图像 1,3 Spin Master Hatchimal Draggle Fur Replacement: 步骤 6 中的图像 2,3 Spin Master Hatchimal Draggle Fur Replacement: 步骤 6 中的图像 3,3
    • Use the spudger tool to push up on the black clip to free it.
    • Pull the clip out.
  7. Spin Master Hatchimal Draggle Fur Replacement: 步骤 7 中的图像 1,3 Spin Master Hatchimal Draggle Fur Replacement: 步骤 7 中的图像 2,3 Spin Master Hatchimal Draggle Fur Replacement: 步骤 7 中的图像 3,3
    • Lift fur up to reveal the next set of clips.
    • Insert a spudger to push up on the black clip to free it.
    • Pull out the clip.
  8. Spin Master Hatchimal Draggle Fur Replacement: 步骤 8 中的图像 1,2 Spin Master Hatchimal Draggle Fur Replacement: 步骤 8 中的图像 2,2
    • Lift the fur up and over the Hatchimals Head.
    • Remove the six 12mm Phillips #00 screws from then body.
  9. Spin Master Hatchimal Draggle Fur Replacement: 步骤 9 中的图像 1,2 Spin Master Hatchimal Draggle Fur Replacement: 步骤 9 中的图像 2,2
    • Pull the casing apart.
    • Remove the yellow speaker cable.
  10. Spin Master Hatchimal Draggle Fur Replacement: 步骤 10 中的图像 1,3 Spin Master Hatchimal Draggle Fur Replacement: 步骤 10 中的图像 2,3 Spin Master Hatchimal Draggle Fur Replacement: 步骤 10 中的图像 3,3
    • Remove the three 7mm Phillips #00 screws from the head.
    • Remove the wheel base and the circuit board carefully not to damage the spring.
  11. Spin Master Hatchimal Draggle Fur Replacement: 步骤 11 中的图像 1,2 Spin Master Hatchimal Draggle Fur Replacement: 步骤 11 中的图像 2,2
    • Push the six black fur clips out using the spudger.
    • Remove the fur completely.
结论
Kimberly Searles
于02/14/18注册
349 声望
创作了2篇指南
团队
USF Tampa, Team S1-G5, Nance Spring 2018 USF Tampa, Team S1-G5, Nance Spring 2018 的会员
USFT-NANCE-S18S1G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 826
