跳转到主内容
Spin Master Boxer Wheel Gears Replacement
你所需要的
  1. Spin Master Boxer Wheel Gears Replacement, Robot Screen: 步骤 1 中的图像 1,1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Wheel Gears Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Wheel Gears Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Wheel Gears Replacement: 步骤 4 中的图像 1,2 Spin Master Boxer Wheel Gears Replacement: 步骤 4 中的图像 2,2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Wheel Gears Replacement: 步骤 5 中的图像 1,1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Wheel Gears Replacement, Robot Wheel Gears: 步骤 6 中的图像 1,1
    • Place robot on back so that the sensors are facing up.
  7. Spin Master Boxer Wheel Gears Replacement: 步骤 7 中的图像 1,2 Spin Master Boxer Wheel Gears Replacement: 步骤 7 中的图像 2,2
    • Gently separate the left set of wheels from the inner portion of the circuit board, by gripping the wheels and pulling them away from main body of robot.
    • There are wires attached to each set of wheels, so be careful not to rip them apart.
    • Repeat the process for the right set of wheels.
  8. Spin Master Boxer Wheel Gears Replacement: 步骤 8 中的图像 1,2 Spin Master Boxer Wheel Gears Replacement: 步骤 8 中的图像 2,2
    • Use the Phillips #00 Screwdriver to remove the 3mm screw that connect the black wheels to the gears.
    • You will have to go through the black wheel to unscrew some of the screws.
  9. Spin Master Boxer Wheel Gears Replacement: 步骤 9 中的图像 1,3 Spin Master Boxer Wheel Gears Replacement: 步骤 9 中的图像 2,3 Spin Master Boxer Wheel Gears Replacement: 步骤 9 中的图像 3,3
    • Grip wheel, and gently pull up, to separate white gear casing into its front and back panel.
  10. Spin Master Boxer Wheel Gears Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, grip defective gear, and pull up and out of gear system to replace.
结论
Lauren Roide
于04/16/19注册
739 声望
创作了5篇指南
团队
Cal Poly, Team S1-G1, Maness Spring 2019 Cal Poly, Team S1-G1, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G1
4 名成员
创作了10篇指南
3指南评论
This is super useful guide and picture are clear for the steps. Will be excellent to know where to buy these gears replacements?
Javier Perez - 回复
Hello. Thé motor seems to be broken. Do you Knowles ils spec to buy à New one.
Sorry, im french...
Tanks.
Jerome Carbonneaux - 回复
Do you know its spec to buy a new one?
Realy sorry...
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 45
总计 4,123
