跳转到主内容
Spin Master Boxer Robot Screen Replacement
你所需要的
  1. Spin Master Boxer Robot Screen Replacement, Robot Screen: 步骤 1 中的图像 1,1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Screen Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Screen Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Screen Replacement: 步骤 4 中的图像 1,2 Spin Master Boxer Robot Screen Replacement: 步骤 4 中的图像 2,2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
结论
另外一个人完成了本指南。
Lauren Roide
于04/16/19注册
739 声望
创作了5篇指南
团队
Cal Poly, Team S1-G1, Maness Spring 2019 Cal Poly, Team S1-G1, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G1
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 678
