跳转到主内容
加入维修社区 - 创建账户
Spigen Kuel TS36 Car Mount Spring Replacement
你所需要的
  1. Spigen Kuel TS36 Car Mount Spring Replacement, Spring/coil: 步骤 1 中的图像 1,2 Spigen Kuel TS36 Car Mount Spring Replacement, Spring/coil: 步骤 1 中的图像 2,2
    • Pull the phone holder off the mount by applying force; the parts will not actually break from the pressure. Temporarily remove the two round half-socket covers on the ball socket, as they are prone to slipping off.
  2. Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 2 中的图像 1,1
    • Remove four 5.0 mm screws from the backing panel of the phone holder using the Oval shape screwhead. Push out wing panels to release the mechanism, and remove the screws and holder from the backing panel.
  3. Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 3 中的图像 1,2 Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 3 中的图像 2,2
    • If either of the springs have not ejected from their slots, proceed to pull them out gently so that the chassis the wing panels are connected to remain undisturbed.
  4. Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 4 中的图像 1,2 Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 4 中的图像 2,2
    • Insert two new 2.6 cm springs as you would batteries to a tv remote. Be cautious as to keep the chassis in place during this process.
  5. Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 5 中的图像 1,2 Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 5 中的图像 2,2
    • Pull out of the wing panels to re-engage the mechanism, holding the center of panels down.
    • The backing panel will not be able to properly be reattached unless the mechanism is is engaged, and the springs are bunched.
  6. Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 6 中的图像 1,2 Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 6 中的图像 2,2
    • Slide the backing panel over the frame of the holder, aligning the sides. Press the button on the center of the holder to once again disengage the mechanism. This will allow the panel to fully slide back into place.
  7. Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 7 中的图像 1,1
    • Rescrew backing with oval head screwdriver to reassemble the phone holder’s backing.
  8. Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 8 中的图像 1,2 Spigen Kuel TS36 Car Mount Spring Replacement: 步骤 8 中的图像 2,2
    • With moderate to heavy force, apply pressure to the ball joint into the socket.
结论
另外一个人完成了本指南。
Ramy Huynh
于09/30/19注册
172 声望
撰写一个指南
团队
CSU Fullerton, Team S1-G1, Bruce Fall 2019 CSU Fullerton, Team S1-G1, Bruce Fall 2019 的会员
CSUF-BRUCE-F19S1G1
4 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 59
总计 1,454
