跳转到主内容
Sphero Ollie Motherboard Replacement
你所需要的
  1. Sphero Ollie Motherboard Replacement, Tires and Hubcaps: 步骤 1 中的图像 1,1
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Motherboard Replacement: 步骤 2 中的图像 1,2 Sphero Ollie Motherboard Replacement: 步骤 2 中的图像 2,2
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie Motherboard Replacement: 步骤 4 中的图像 1,2 Sphero Ollie Motherboard Replacement: 步骤 4 中的图像 2,2
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie Motherboard Replacement: 步骤 5 中的图像 1,2 Sphero Ollie Motherboard Replacement: 步骤 5 中的图像 2,2
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
结论
2等其他人完成本指南。
Krystal Hedrick
于10/30/17注册
364 声望
创作了3篇指南
团队
UW Tacoma, Team S1-G3, Rose Fall 2017 UW Tacoma, Team S1-G3, Rose Fall 2017 的会员
UWT-ROSE-F17S1G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 721
