跳转到主内容
Zenbre SoundBank Z3 Speaker Grill Replacement
你所需要的
  1. Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Grill Replacement: 步骤 2 中的图像 1,1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Grill Replacement: 步骤 3 中的图像 1,2 Zenbre SoundBank Z3 Speaker Grill Replacement: 步骤 3 中的图像 2,2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: 步骤 4 中的图像 1,3 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: 步骤 4 中的图像 2,3 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: 步骤 4 中的图像 3,3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: 步骤 5 中的图像 1,3 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: 步骤 5 中的图像 2,3 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: 步骤 5 中的图像 3,3
    • Remove the three silver Phillips screws from the plastic ring that holds the speaker in place.
    • Be careful not to rip out the speaker while taking out the screws
    • The same steps can be done on the other side of the speaker
  6. Zenbre SoundBank Z3 Speaker Grill Replacement: 步骤 6 中的图像 1,3 Zenbre SoundBank Z3 Speaker Grill Replacement: 步骤 6 中的图像 2,3 Zenbre SoundBank Z3 Speaker Grill Replacement: 步骤 6 中的图像 3,3
    • First, remove the speaker from the motherboard, then remove the ring that held the speaker in place.
    • These are the joints that need to be soldered. Follow this guide link to help you remove the wires from the motherboard.
    • How To Solder and Desolder Connections
  7. Zenbre SoundBank Z3 Speaker Grill Replacement: 步骤 7 中的图像 1,2 Zenbre SoundBank Z3 Speaker Grill Replacement: 步骤 7 中的图像 2,2
    • With the plastic ring removed, the speaker should slide out easily.
    • Be careful not remove other components in the speaker
    • This will expose the speaker grill
  8. Zenbre SoundBank Z3 Speaker Grill Replacement: 步骤 8 中的图像 1,3 Zenbre SoundBank Z3 Speaker Grill Replacement: 步骤 8 中的图像 2,3 Zenbre SoundBank Z3 Speaker Grill Replacement: 步骤 8 中的图像 3,3
    • Now that the speaker has been removed, the plastic grill should be visible.
    • With a little bit of force they can be pushed out.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 UMass Dartmouth, Team 3-2, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S3G2
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 514
