跳转到主内容
Speaker Bose SoundDock Motherboard Replacement
你所需要的
  1. Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: 步骤 1 中的图像 1,2 Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: 步骤 1 中的图像 2,2
    • Remove the battery by pressing your finger down on the center button and twisting it counter-clockwise.
    • Remove battery and set it aside.
  2. Speaker Bose SoundDock Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use a plastic scraper to remove the rubber gasket from the bottom of speaker system and set it aside.
  3. Speaker Bose SoundDock Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use a standard sized Phillips Screwdriver to remove the four screws on the bottom of the speaker system.
  4. Speaker Bose SoundDock Motherboard Replacement: 步骤 4 中的图像 1,1
    • Using a smaller flat head screw driver, unscrew the semi-circle plate from bottom to expose the motherboard.
    • Once the components are unscrewed, the plastic dock frame may fall out.
  5. Speaker Bose SoundDock Motherboard Replacement: 步骤 5 中的图像 1,1
    • Gently pull both ribbon cables out of the motherboard.
  6. Speaker Bose SoundDock Motherboard Replacement: 步骤 6 中的图像 1,1
    • Replace it with new motherboard by plugging in the thinner wire into the small slot, and the larger wire into the wider slot.
    • Reverse steps 1 through 4 to reassemble dock.
结论
Dalton Alexandre
于02/24/15注册
123 声望
撰写一个指南
团队
Cal Poly, Team 24-5, Green Winter 2015 Cal Poly, Team 24-5, Green Winter 2015 的会员
CPSU-GREEN-W15S24G5
3 名成员
创作了4篇指南
一条评论
Where can you buy the motherboard?
Steffen Jensen - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 18
总计 3,276
