简介
Applicable to H4D and H4Bt engines (M281 E10 and M281 E09)
It is advisable to do this operation on a cold engine.
Recommendations :
Replace every: 60,000km/4 years (Iridium) or 20,000km (Copper/Nickel).
Electrode gap: 0.8mm (varies depending on the spark plug model considered)
H4Bt: Iridium spark plugs mandatory.
H4D: you may favor Iridium spark plugs if using E85.
See Wiki for more info.
你所需要的
Unscrew the 6 T50 screws by hand or using a wrench and a socket.
Lift and put aside the engine hood.
Disconnect and put aside the oil vapors duct.
Disconnect the ignition coils' connector.
Unscrew each 8mm bolts of the 3 ignition coils.
Gently extract the ignition coils.
Unscrew and extract the spark plugs using a 14mm spark plug socket.
Torque the new spark plug using a 14mm spark plug socket at 24 N.m.
Put back the ignition coils on the spark plugs.
Torque each of the 3 ignition coils' 8mm bolts at 10 N.m.
Reconnect the ignition coil's connectors.
Congratulations ! You replaced you spark plugs/ignition coils !
6等其他人完成本指南。
由衷感谢以下译者:
42%
AntonioBiscuit正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
