跳转到主内容
加入维修社区 - 创建账户
SoundBot SB571 Battery Replacement
你所需要的
  1. SoundBot SB571 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Before disassembling the speaker, make sure it is powered off.
    • Place the speaker on a flat surface.
    • Take your blue plastic opening tool and remove the outside cover.
  2. SoundBot SB571 Battery Replacement: 步骤 2 中的图像 1,1
    • Reorient the speaker so the black panel is facing up.
    • Remove the 4, 0.9 cm screws from the back panel using a Phillips PH1 screwdriver.
    • Now remove the plate.
  3. SoundBot SB571 Battery Replacement: 步骤 3 中的图像 1,1
    • Reorient the speaker so the bottom is facing up.
    • Remove the 4, 0.9cm screws from the bottom using a Phillips PH0 screw driver.
    • Now open the plate.
  4. SoundBot SB571 Battery Replacement: 步骤 4 中的图像 1,2 SoundBot SB571 Battery Replacement: 步骤 4 中的图像 2,2
    • With the bottom plate removed now use the blue plastic opening tool to lift up the circuit board from the device.
  5. SoundBot SB571 Battery Replacement: 步骤 5 中的图像 1,2 SoundBot SB571 Battery Replacement: 步骤 5 中的图像 2,2
    • Disconnect the battery wires from the circuit board.
  6. SoundBot SB571 Battery Replacement: 步骤 6 中的图像 1,3 SoundBot SB571 Battery Replacement: 步骤 6 中的图像 2,3 SoundBot SB571 Battery Replacement: 步骤 6 中的图像 3,3
    • Reorient the speaker so the back side is facing up.
    • Now that the battery wires have been disconnected, use a blue plastic tool to release the battery from the adhesive strip.
    • Loop the battery wires through the opening in the back plate.
    • The battery and it's connective wires have been completely removed from the speaker.
结论
12等其他人完成本指南。
Yana
于02/09/16注册
672 声望
创作了2篇指南
团队
USF Tampa, Team 2-50, Cagle Spring 2016 USF Tampa, Team 2-50, Cagle Spring 2016 的会员
USFT-CAGLE-S16S2G50
4 名成员
创作了2篇指南
9指南评论
Please provide the source to buy the replacement battery
Madhu Mohan Bhukya - 回复
Sir ,m n jully m flipcart se soundbot buy tha jisme kuch dikat aa rhi h bettery ki bajah se
Raj Saini - 回复
They don't sell batteries!!
international.loop - 回复
It says above that battery not for sale.
A simple online search and you will find the battery.
Mark Friend - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 58
总计 9,312
