简介
La batteria non dura più a lungo? Sostituiscila.
你所需要的
Infila un plettro il più a fondo possibile nella fessura sul bordo destro dell'iPod, tra la copertura anteriore in plastica e la copertura posteriore in metallo.
Usa il plettro per fare leva sulla copertura anteriore e rilasciare i cinque ganci di bloccaggio (mostrati nella terza immagine).
Fai scorrere il plettro lungo il bordo dell'iPod e continua a fare leva per rilasciare i ganci restanti.
Dopo che tutti i cinque ganci del bordo destro sono stati rilasciati, La copertura può essere facilmente aperta.
Scollega attentamente il connettore bianco della batteria dalla scheda madre. Assicurati di tirare solo il connettore e non i cavi.
Per rimontare il tuo dispositivo, segui le istruzioni in ordine inverso.
588等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
62条评论
Biggest trouble I had was step one. I actually broke the edge off the large tool. A note somewhere else on this site recommended using a razor which work far more easily then the large blue tool. Common sense, your using a sharp razor, be careful!
As previously noted the screws are TINY, very easy to lose of you drop one.
I jockeyed the battery to get just a crack of space and then used the spluger tool to pry the battery free from the adhesive, very strong.
My IPOD is currently recharging for the first time in years. :o)
I have a 4thG original ipod. This was a simple process and it was successfully completed. The ipod was able to be synced after 6 months of sitting in a drawer. The only issue so far is that the entire ipod gets warm to the touch while it's charging. Hopefully that will lessen after subsequent charges. The only bit of confusion in the instructions is the beginning step of inserting the ipod tool at the top. I thought I was trying to unlatch a tab there but there is none on top. Otherwise everything else was clear and exactly as described and pictured.
Ifixit, you're awesome !!! Took me about 10 minutes and now I have my 18,000 tunes library back. Marley, LedZep and Pink Floyd are alive again. If a 60 year old can do it, anyone can. Iriemon. 10/17/2013
